跳转到主内容
The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
108 个问题 查看全部
Touch Not responding unless your holding connection
Hello
I changed a Screen/Digitize on a Samsung Tab A. When push the home button it responds . When you try to tap the screen it won’t respond. When I press the ribbon connector to the chip it responses fully.
When you stop using it for more then a minute it take a while to response to the touch again.
I’ve tried taping the cable down to keep it secure and dosen’t help.
Any Help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I assume you mean that you replaced the touch screen on your Galaxy Tab A. Replacement of the touch screen can be tricky at best.
With the unit off, and preferably no battery, (for safety), unplug the cable, and clean all related connectors with rubbing alcohol, and a Q-Tip. Wait about 5 minutes for everything to air dry, then reassemble, and try again.
If this doesn’t work, then either the new screen is defective, or something was missed during reassembly. At this point, I’d suggest having a professional repair it for you.
这个答案有帮助吗?
得分 0
2条评论:
I did that. It work when I hold the tab on the board in the back. I've tried three screens and two out of three work. I think the tab that holds it down isn't strong enough. Order new attachment and going to replace.
完成的
Just sent it away to be check by another company and they are having the same issue.
完成的
添加一条评论
添加你的答案
rcreaser 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 56
