跳转到主内容
Repair guides and support for shredders of paper, credit cards and any other documentation.
34 个问题 查看全部
Why is Fellowes DM8C Paper Shredder Jamming?
When I look into the feed slot, I can see paper jammed in the cutting cylinders. I’ve removed the lid and cleaned out every bit of paper from the cutting cylinders multiple times (no easy task). But shortly after doing so, the shredder jams again. I’ve oiled the cutting cylinders, which used to help. But now the shredder will only accept about 1” of paper before jamming again. I read the comments here on a different Fellowes model, but they don’t apply to my situation. On principle, I’d prefer to try and fix the problem rather than buy a new shredder; however, I don’t want to spend more on a replacement part than I would on a new shredder. Any suggestions would be helpful.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi. If your machine is constantly jamming, the problem could be that you have broken stripper plates. These are the plastic (or sometimes metal) plates that sit between the cutters and make the paper fall into the bin. If they are broken or snapped off the paper can just constantly go around the cutters until it Jams. If you have any questions or would like any more help please visit www.shredderrepair.co.uk and we would be more than happy to help.
Matt
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kathy Hirsh 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 17
总计 498
