跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Touchscreen does not work while on charge
I bought a 5s off of eBay for $20, not turning on or booting. I replaced that battery and dock connector, and it worked great. The touchscreen was fine and everything worked perfect. When I put it on charge though, the touchscreen is glitchy, touching apps will bring down the search bar and the scroll on safari is all messed up. When I take it off charge it works great tho. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It seems to be the new charging port. When you charge the phone, thats when it activates the charging port the most. I would try reconnecting the charging port and battery connector and turn it on again to test the charger. If thats not the case than it must be a screen issue that was caused by the previous owner.
这个答案有帮助吗?
得分 0
1条评论:
Before going to all the work doing that, it also is worth seeing how well it works charging it using a different charging cable and/or wall adapter. Sometimes a cheaply made charger can interfere with the display's functionality. If it's not that though, it likely is something with the display, or the new charging port.
完成的
添加一条评论
添加你的答案
Andrew Coppola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 36
