跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
iPhone 7+ Touch Issues
I know there were issues with IOS 11.3 and that was resolved. I have recently been getting a rash of comebacks with touch issues with the 7+ and only the 7+. I buy the OEM screens from multiple vendors. The repair goes fine and the touch is working fine, but a few days or a week later, they will be back. I am at the point where I don’t want to work on the 7+. Any thoughts or ideas would very helpful.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The problem is with your OEM screens.
The 7/8 series original screens are made by several manufacturers (Toshiba, LG, Sharp) and each phone is calibrated to the screen it has installed. It’s important not to mix and match screens. So for example, if your phone had an original LG screen, you should replace it with an LG screen. This issue seems to be more prevalent on the Plus devices; they can be quite picky when it comes to replacement screens.
The only way to know which screen manufacturer you have is to look at the QR Code on the 3D Touch panel. However, even if you have a screen with the same code, it may still be a franken-screen. Lots of refurbish shops mix and match an LCD from one vendor, a 3D Touch panel from another, etc. All you can identify is the 3D Touch panel.
Check out this blog (not affiliated) to learn more. It explains how the different mix of products affects the reliability. It turns out that some franken-screens have a much higher prevalence for Touch issues than others.
Curiously enough, aftermarket screens don’t suffer from this issue at all. Unfortunately, they tend to have bland colours and in some cases poor construction quality. A good alternative is a SHARP In-Cell Technology (“in-cell”) screen.  They don’t suffer from the touch issues like other aftermarket screens, but they have great colours and are less expensive than OEM screens. They can be a bit hard to find but offer the best compromise. Different vendors sell them under various branding but they generally state “in-cell” somewhere in the description.
这个答案有帮助吗?
得分 4
添加一条评论
添加你的答案
seth swain 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 112
