跳转到主内容
The Acer Chromebook CB3-431-C5EX is a fourteenth generation Chromebook released in May 2016. The 14-inch Acer Chromebook 14 is made to have a full HD screen and up to twelve hours of battery life.
13 个问题 查看全部
Acer Chromebook: blown motherboard component?
My father’s Acer Chromebook 14 (CB3-431) will no longer power-on. It worked fine for 18 months before one day it no longer charged. Once the battery ran down it no longer powers on.
I suspected the power port might be at fault, as the socket is quite loose. When removed the back I noticed a white mark on the motherboard near to what I believe is the charging circuit.
Now I am no longer sure whether it is worth ordering a new power port.
Does anybody know if this looks like a blown motherboard component?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It’s hard to tell from the picture. A blown motherboard component would have probably made a noise and emitted some kind of smell when it detonated. Also, the computer would have likely become symptomatic immediately.
It could be a blown component, or that white mark could be because of a manufacturing defect. Perhaps the unit is refurbished, or was otherwise handled by a technician who damaged it?
To make sure that the power port is at fault, I would probably first replace the battery and see if that doesn’t fix the issue. It’s always best practice to try the least invasive solutions first.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Steve Larkin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 225
