跳转到主内容
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
678 个问题 查看全部
Why is my touch screen unresponsive?
I currently have a iPhone 8 Plus, After recently updating to IOS 12 my touch screen has become completely unresponsive, I’ve swapped the screen before due to it being damaged although it worked fine once I swapped it since I’ve updated though I’ve had nothing but issues, Could this be a hardware issue? I don’t think it’s software as I’ve tried restoring about 4 times all with the same problem.
any suggestions would be appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The first thing that you will want to do is of course physically check your touch screen for any signs of damage. Check to make sure that it is clean, and that there's no dirt or oils that could be interfering with touch. Also check that there's no apparent water damage.
You can perform a hard reboot which is an easy but helpful method. This can fix a wide variety of issues.
You can also try a factory reset. Before you reset, make sure to back up your data either using iTunes, iCloud, or a third-party app
If it is a hardware issue, you will have to contact Apple and possibly have your screen replaced.
这个答案有帮助吗?
得分 0
2条评论:
I’ve tried both the soft and hard resets, Cleaned the screen, The screen wasn’t replaced by Apple before so probably won’t be touched this time
完成的
It maybe a hardware issue, you may go to local repair house to check and spot the problem, thanks!
完成的
添加一条评论
添加你的答案
g.breslin91 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,401
