跳转到主内容
The Hp Notebook 15-ba018ds is a touchscreen capable laptop equipped with Windows 10 operating system. It is 16 x 10 x 3 inches when closed and weighs 4.83lbs.
Why does the screen turn foggy and inoperable
Screen suddenly turns foggy; cursor is a large plus sign, but ineffective unless the Windows key on keyboard is used to bring up start panel. I have not learned a sure way to get my working screen usable.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
My device is an "HP 15 Notebook PC''; was not listed among devices to choose from.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @dollydragon ,
Check if the clicklock feature has been enabled in the laptop.
Update (04/23/2019)
Hi @dollydragon ,
There was a new feature introduced in Win 10 recently where if you press the Windows key + shift key + s key (3 keys together) it allows you to select and copy automatically to the clipboard anything on the screen. You drag the cursor, (which is a large + sign) around to suit the size of the screen that you wish to copy.
You then can "paste" it where you like in any document etc.
Is this what is happening on the screen?
这个答案有帮助吗?
得分 2
5条评论:
jayeff, clicklock is not enabled. Should it be? I don't always get the mouse pad to copy and paste. . .sometimes have to repeat several times. But maybe because I tend to not use the two little independent keys. On my Chromebook my mouse was only the pad, nothing else.
完成的
Hi @dollydragon ,
Clicklock should only be enabled if you wish to use the feature.
What is the full model number of your PC? (should be on a label on the back or underside of the case)
What OS is installed in the laptop?
Does the problem occur only when using a particular program or it doesn't matter what you are doing?
完成的
Thank you @jayeff; I appreciate your time and interest in helping.
Clicklock was off when I checked it. Did not turn it on.
Model # 15-1233wm
Windows 10 Home
Version 1803
It happens when I am typing a document or working on emails; I don't do much else. I am using Google Chrome for email and documents.
完成的
YES! I just tried it. . .that is it! Thank you. Woohoo, now I can get it turned off .
So, the keyboard is too sensitive for my touch; surely I can find a way to change that setting!
So appreciate your help.
完成的
Hi @dollydragon ,
This link may be of some help
Either that or just click on the x in the box at the top of the screen when the "copy" feature is on
完成的
添加一条评论
添加你的答案
Darlene Dragavon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 12
总计 778
