跳转到主内容
Repair guides and support for motorcycles manufactured by Suzuki Motor Corporation.
127 个问题 查看全部
Slipping after I been riding for 20 mins and it heats up
Okay so i have a 1995 rf900r and kts been running fine until recently.. Now when i first start the bike and ride it will run through all the gears fine but after 20 minutes or so no matter what gear im in if i apply too much throttle the bike will just rev and not take off .. However if i apply the throttle slowly i runs fine in all the gears this is only happening after the bikes been running for 20 minutes or so its my first bike and im not sure what it could be please help….
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Clutch pack is probably on its way to used up. You should find someone with right tools and expertise to replace it. You could also acquire the tools and knowledge to do it for yourself if you are willing to learn why the shops charge so much to do this job. A second possibility is that there is not enough freeplay (or maybe even no freeplay) in the clutch actuation mechanism and that is causing the slippage as the clutch pack heats up to (and probably beyond in your case) operating temperature. A simple adjustment might restore the clutch to normal operation but don’t expect it to last forever if such an adjustment “fixes” it. All the burnt lining contamination in the oil is not very good for the rest of the internal parts… stopping up oil filters and impeding oil supply is a big concern. Or maybe you have this problem… https://www.youtube.com/watch?v=D-KThaAZ...
这个答案有帮助吗?
得分 2
1条评论:
Hi,
To add to the answer, here's a link to the service manual which may be of some help.
完成的
添加一条评论
添加你的答案
Phil S 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 3
总计 50
