跳转到主内容
加入维修社区 - 创建账户
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
kinked heat sink, is there a thermal conductor that I can put on it?
I have an Inspiron 1545, It has a kinked heat sink, but it still seems operational, and when i’m using Youtube , or at random times, the fan starts running a lot, is there a thermal conductor that I can use to put on my heat sink till I get enough money to replace it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Hi @fegelein3290 ,
Here’s one that should be within your budget.
You won’t get it much cheaper than this.
这个答案有帮助吗?
得分 4
添加一条评论
The system requires a heat sink to pull the heat away. There isn’t any options here if yours is damaged.
Think it like this turning on the sink faucet the water needs to drain out in the basin. The heatsink heat pipe is like a tube which connects the two so when it fails the heat (water) can’t exit.
这个答案有帮助吗?
得分 0
2条评论:
I understand what you are saying, but the heatsink is still transferring heat and when you look closely its not entirely kinked, if it was fully kinked i wouldnt be able to open this tab and type this message
完成的
The kink is effecting its performance, thats why the system is still able to work. Once the systems thermal sensors are driven too hot the system with either shutdown or go into safe mode. You need to get the heat sink replaced.
完成的
添加一条评论
添加你的答案
Brayden S 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 288
