跳转到主内容
The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 个问题 查看全部
iPad screen unresponsive even after new screen installed
I have an iPad 2 A1567. The iPad was not dropped nor in any way treaded poorly but one day, it just stopped responding to touch. Reboot, Factory restart, Clean install of new current iOS, nothing seemed to get the touch screen to work. Everything else works just fine from camera to volume buttons to home button to power button, etc. It just wouldn’t respond to touch.
So I bought a replacement screen. After install of replacement screen, the screen problem remained but all other external buttons still work just like before!
I looked at my iPad screen connectors with magnifier and pin 8 on the bottom sock on the bottom row looks like it MIGHT had had dirt. With a blow of compressed air, it is now gone but the screen will still not respond to touch.
I suspect this is a hardware and not software issue but it must be on the Motherboard. Any thoughts about reasons or hardware failures as to why an iPad 2 with a new screen still won’t respond?
Rob
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
the connector might be damaged, unless you know how to microsolder you {might} be out of luck, im not sure,
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rob Stokes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 33
