跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
I cant enter my password in the log in because of keyboard malfunction
Out of nowhere, my macbook keyboard suddenly started malfunctioning. Its stuck on the shift key, because i cant type lowercase letters or numbers. The problem is, i cant log in to my macbook because my password has lowercase letters in it. How do i fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hello Patee,
You can try to clean the button with isopropyl alcohol in the off state.
Connect an external keyboard for now. If this doesn’t help, you have to replace it, by opening the system.
But only if you know what your doing. I’m sure there is a dissasembly manual here on ifixit.
Geetz mischakuh
这个答案有帮助吗?
得分 1
1条评论:
Take a look at this How to remove and clean MacBook Pro Retina SHIFT key
Here's the guide to pull the bottom cover MacBook Air 13" Early 2015 Lower Case Replacement and here's the other guides as the 2015 is the same MacBook Air 13" Early 2015
完成的
添加一条评论
添加你的答案
Patee Reyes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 564
