跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
iPhone reboot loop problem
I have an iPhone 6 that has a reboot loop. I tried to restore it and got error 9 so I replaced the charge port and still got error 9. I then heated up the board with my hot air station and tried the restore again and it succeeded but once the board cooled down it rebooted and started the loop again. Could it be the TriStar ic or is the nand bad?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
That is the easy way to find that shows error 9.
1- From Nand that can be solved by removing and reprogramming by programmer
2- Loose contact between CPU & RAM.
you tell that phone working after heat up board is that the problem from CPU to SDRAM loose connection that is the mistake of apple design in 6 & 6plus series phones that the error 9 cause.Such problem i solved many by this way but you have to understand that is slightly hard. you need micro soldering repair skills and instruction on it.
The I2C line have broken cause that problem .
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Robert 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 77
