跳转到主内容
The Samsung Galaxy S6 Edge+ is the larger variant of the Galaxy S6 Edge smart phone.
99 个问题 查看全部
help me to fix my phone pls
Hello ..
i have samsung s6 edge + ( sm-g928f ) i love this device and been using it since 3 years ..
yesterday i wonted to root it but couldn't so i road about that and i had to turn off the OEM
after root was every thing good until i enable OEM and restart the device ..
it stak in boot screen with red line ( Binary Blocked by FRP Lock on )
i didn't knew what i should do so i try every thing i know to backup the file i couldn't ,,
finally i fleshed a stocked ROM from Sammobiel and plug it in the charging cable and installed every thing i need from store ..
after that Evey time i unplug the phone from phone 10 sec freeze and turn off so i flashed second time another ROM and third from sammobile
if the phone was unplug and i turn it on when i get the phone menu restart immediately
i tried safe mode the same
what i the problem is it from firmware of from device ( ic ,battery , charging port or .. )
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
It’s usually either wrong firmware was flashed on the phone or phone was not factory reset in recovery mode after flashing.
SM-G928F, make sure that the firmware is the latest version for your phone as well. Try factory resetting first and see how that goes in recovery mode.
这个答案有帮助吗?
得分 2
1条评论:
i downloaded the last firmware but always turn off when i unplug the charger after 10 sec idn what i should do :(
完成的
添加一条评论
添加你的答案
rimon 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 9
总计 203
