Why doesn't it power on
My laptop stopped showing life signs( no lights,no bootup) then i opened it and removed the power button and plugged in the ac cord and it showed lights…but i couldn’t turn it on so i plugged the power button and it didn’t show any light more…help!
3条评论
You wrote "power button". Did you mean "battery" ? If that is the case, how long did you wait, after plugging in the battery charger, before attempting to turn it on.
If the battery is completely flat ( no charge) there will be NO residual power on the motherboard. In this case it may take several seconds before it will switch on. So plug in charger, lights come on, wait about 10 seconds or so and then try to switch on the laptop.
由 mike 完成的
I clearly meant the power buttom
由 Matteo Mireuta 完成的
The battery is fine the...if i plug the power button in the laptop doesn't show life...if i unplug it, it shows the charging light but then i can't turn it on because the power button is unplugged
