跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
iPhone 4s bent frame, charging port pins snapped
Hello, I just bought a lot of iPhone 4s off eBay, and one of them is bent and has snapped charging pins.i was wondering if I could repair the bend, because I know I can replace the charging port. I just want to know if I can do anything about it or just use it for parts
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I’m not sure if I understand your question, but why don’t you just buy a new frame? They’re pretty cheap on eBay.
完成的
添加一条评论
1个答案
已选择的解决方案
Yes you can fix the bend. Framework is very common at my shop but since it is an iPhone 4s, The aluminum is very soft because the phone is old. When doing framework, make sure to give it very light taps to get it where you want to be. Of course with framework, perfection is very hard to achieve but it does the job enough to where everything in the phone will work just fine. Best of luck to you!!!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Luk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 94
