跳转到主内容
Can I cut charger and connect wires to rechargeable speaker wires
I broke my mirco use charging port for my speaker and i don’t have cash to fix it. Would is be possible to cut my phone charger and the connect those wires
charger:Blue Red
Speaker:Black Red
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
Are those wires (Black and Red) connected to the speaker itself? If it does, you snapped the wrong wires. Solder them back to the board. You could solder a connection but the speaker won’t be portable anymore (since the charger is soldered into the board of the speaker). Solder the Positive wire of the charger to the positive terminal (the place where the micro usb connector is attached) and negative to the negative terminal.
这个答案有帮助吗?
得分 0
添加一条评论
Yes just match color code for each jack
Most jack are the same colors just rearanged.as jacks progress so does the number of paired wires.
这个答案有帮助吗?
得分 0
添加一条评论
Sounds to me like ur dealing with a short
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
rbo 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 20
总计 2,899
