跳转到主内容
The Hover-1 Horizon is a self-balancing electric scooter that has built in Bluetooth speakers, LED headlights and a rechargeable battery. Model: HY-H2L-Hover-1 Horizon
2 个问题 查看全部
Hall Sensor on HOVER-1 registers faulty. How do I repair that?
After successfully calibrating my hoverboard I turn it off and then back on and climb in the seat of “the buggy”, the HOVER-1 seat attachment, I try to move forward by pushing gently down on both controls evenly. I start to move but suddenly the RIGHT side “gives in” and there is no response from that side. There seems to be zero power going to that wheel. It will work again for a moment after turning off/on but it always stops operating. When it goes out there is no resistance and does not spring back like it should. So running the diagnostic test on the HOVER-1 app it shows the screen labeled “A”.
“HALL SENSOR Fault“
So my question is '''what can be done about this? Does this typically mean I will need replacement parts or does it mean a lose wire?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
Did you ever find out the answer? I have the same exact issue right now and haven't found an answer!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kyle johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 22
总计 750
