跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Screen replacement with few issues.
Replaced screen and no display. It connects to itunes. Home button works as i can feel it. The vibration does not turn on when i press the switch down. Also the original screen does not work. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Disconnect all the flex cables from the motherboard and examine both ends with a magnifier for damage and debris. There are small soft gaskets around all of the plugs on the motherboard to help keep the phone water resistant, and if you aren't careful it's pretty easy to pinch that gasket between the conductors when you're plugging in the cables. This will disrupt the signal and can cause the screen to appear to not work.
完成的
I checked all connections. No obstructions.
完成的
添加一条评论
1个答案
Check the flex cable connection from the LCD.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Cole Helgeson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 52
