I need a replacement LCD touch screen is this even possible
I need a replacement screen for my mfc j6920dw is this possible as I cant find one anywhere
Hi @chrisw15 ,
I think that this is what you’re after.
The part number is LED448001 found in this printer parts list (scroll to p.17).
There may be other suppliers which suit you better. Just search online for LED448001 to get results
这个答案有帮助吗?
Check this page from printcopy.info to see all the parts you might need. The referenced part above appears to be the Touch Panel Assembly only, and there is an LCD also just in case your LCD is cracked too.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 29
总计 5,540
2条评论
Hi Chris
DO you have found a solution for your touch screen ?
I have the same problem, I need a replacement LCD touch screen
Thks
由 Jean Mich 完成的
Has anyone found a touch screen replacement yet?
由 andycobba 完成的
