跳转到主内容
Google公司发布的二代Pixel XL版本,发布于2017年10月19日。配备6英寸圆角P-OLED显示屏。纯黑和黑白两种颜色及64GB或128GB存储空间可选。
72 个问题 查看全部
4G Randomly disconnecting after screen and charging port replacement
Hey, after replacing the screen and charging port on my Pixel 2 XL my cellular data has kept disconnecting. Did i do something wrong? Do i need to open to phone again to fix or buy new parts? Here is a screenshot from the status bar when it disconnects
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
You might want to open the phone again and try reconnecting the connector for the new charging port. Also try rebooting it a few times. The Turn off and back on thing is very old fashion but sometimes it works! Best of luck!!
这个答案有帮助吗?
得分 1
添加一条评论
I had a similar issue with my Galaxy S4 a few years back, when I first started getting interested in repairs. I had accidentally snapped the head off the antenna so it obviously wasn’t connected. I only realized it when my signal was crap and I had to buy a new antenna. It may also be due to the charging port connector as Ian Shalongo said.
Before you go ripping your phone apart though, you should try a few things…
Try rebooting the phone.
Check for any updates. Many Pixel 2 owners had signal problems that needed an update to be fixed.
Try basic trouble shooting steps like popping the SIM out and back in, resetting network settings, etc. There is a really good guide for
https://thedroidguy.com/2019/03/how-to-f...
Good luck and God Bless
这个答案有帮助吗?
得分 0
2条评论:
I have tried the basic steps like taking out the sim and rebooting it multiple times and even done a factory reset on the device without any luck. I think im just going to buy a new display adhesive and rip the phone open to see what i did wrong.
完成的
Did you reconnect both ends of the antenna wire along the right side of the phone?
完成的
添加一条评论
添加你的答案
Mico Hautaluoma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 11
总计 75
