跳转到主内容
加入维修社区 - 创建账户
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
Bluetooth problems on 2012 MacBook
So I have a mid 2012 macbook pro… my bluetooth is on and search for devices but it isn’t finding anything…. my airport is also neither working…. I noticed there seems to be an antenna missing from the board…. hopefully the picture works. I have tried to locate it but it doesn’t appear to be there at all… can anyone help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Review this guide MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board Replacement Jump down to Step 9 are these cables present?
There is also a ribbon cable on the other side that often needs replacement MacBook Pro 13" Unibody (Early 2011-Mid 2012) Airport/Bluetooth Cable. Follow this guide: MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Cable Replacement to replace it.
Replace the cable that connects the wireless board to the logic board compatible with the A1278 Early 2011 to Mid 2012 13 inch Unibody MacBook Pro laptop. Part #922-9780. Identified by 821-1312-02 printed on the cable.图片
产品
$9.99
MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Board图片
指南
难度:
中等
20 - 30 minutes
MacBook Pro 13" Unibody Mid 2012 AirPort/Bluetooth Cable图片
指南
难度:
中等
15 - 25 minutes
这个答案有帮助吗?
得分 1
10条评论:
Hi dan! Thanks for getting back to me, The ones that are highlighted with red circles are present yes but the one that isn’t highlighted in step nine isn’t there...... is this something to so with the bluetooth/Airport ?
完成的
Look at Step 8, this is the Bluetooth cable. It comes out of the displays hinge with the other cables do you see an end floating around?
完成的
Hi Dan, no I can’t see that one at all....
完成的
So this systems Bluetooth never worked then?
Did you have the system serviced at some point?
完成的
Hi dan, no it just searches for devices but nothing ever comes up.......
完成的
显示更多的5条评论
添加一条评论
添加你的答案
Stephen Cosgrove 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,196
