跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
iPhone turns off when unplugged, error 1611 on attempted restore
Received minor water damage 1+ months ago. Dried out, haven't had issues until a few days ago. All moisture sensors white.
A few days ago I unplugged my phone from the wall charger, it turned off instantly. I went into DFU mode and attempted a restore. I get the error message 1611 in iTunes. Did a lot of research, sounds like a hardware issues. I started with the battery since it's the cheapest and logical. Replaced the battery, same issue.
What is the next step? Replace the dock connector? Power and sensor cable?
Thank you :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
2条评论
Sure sounds like a battery issue or charging circuity damage, Maybe the dock port just needs to be cleaned very well with isopropyll alcohol. But anyway, try a regular Recovery Mode Restore. With iTunes open, hold down Home button and connect iPhone to computer with USB cable. Keep holding Home button until iTunes recognises iPhone in Recovery Mode, then Restore the Firmware.
完成的
Thanks Brad, I've already tried this. I might just take it to a local professional.
完成的
添加一条评论
2个答案
最有帮助的答案
Or even if the headphone/ dock connectors are tripped break out the scissors, paper, and glue stick. I would attempt to replace dock connector or at the bare minimum give it a good cleaning as it sounds like some corrosion is setting in.
All else fails warranty :)
这个答案有帮助吗?
得分 1
添加一条评论
If all of your liquid sensors are white still, you could take it to Apple and they will most likely still replace it, if it's still under warranty. I will leave you with the ethical dilemma, of whether you should or not, in your hands...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Joel 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 10,662
