跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
iPhone 6 PP1v8 powerrail
Hello.
I have a iphone 6 with weird value on PP1v8 power rail.
It should show 1,8 V but it is showing 2,70 V . Does anybody have similar issue ?
DCPS show’s 0 Amp’s before powering it up.
PP_VCC_Main - OK
PP_BAT_VCC - OK
DCPS after pressing power button constant 0,22 Amp.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Diode mode shows a good value as 339 ( ZXW shows 313), this small differenece cant be issue ?
Measured the cap near to nand.
完成的
添加一条评论
2个答案
最有帮助的答案
Is it showing image or taking charging current through a usb amp meter
这个答案有帮助吗?
得分 1
4条评论:
Hei,
From the board right now is missing Tristar, Backlight IC and Display IC.
Should it be still showing normal values on PP1v8?
完成的
I would replace the 3 to see what happens after
完成的
But still - Shouldnt the PP1v8 still be 1,8 Volt's even if these chips are missing.
完成的
What component are you testing for 1v8
完成的
添加一条评论
Some where 3v connect to 1.8 that value shows 2.7.I also faced the same problem but i can`t solve it.I think under layer of the phone is shorted i think.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kaspar 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 5
总计 110
