跳转到主内容
Dancing water speakers are computer speakers that feature jets of water illuminated by bright multi-color LED lights.
9 个问题 查看全部
Speakers are screaming. PLEASE HELP
Water is shooting up np and the lights work but there is a sound like a scream whenever it happens. tried turning down and even at a low volume it still screams when the water shoots up. I really like these speakers and use them for gaming and I dont want to have to replace them. Please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
Sounds like either the water pump (more likely) and/or the pressure fan (less likely) is shot. Here's a good video that explains how these work:
https://www.youtube.com/watch?v=vfU6iV-R...
I would go with a dying pump motor. Take it apart, find the part number, locate it online, and replace.
这个答案有帮助吗?
得分 1
1条评论:
ty so much I will give it a shot
完成的
添加一条评论
It’s probably you’re playing it at a low volume that’s why same here as I got watt speakers to when I full blast it it’s fine but when the volumes low it makes weird noises
这个答案有帮助吗?
得分 0
添加一条评论
Just sorted this exact issue , its the grease around the motor spindle runing dry ! , take apart apply lithium grease and or WD40 to the spindle , then test to work the grease into the motor ...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mamac253 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 44
总计 1,475
