跳转到主内容
After Xperia Z series, Sony has made a new flagship, the Xperia X series. Sony Xperia X Performance was released at Jun, 2016. It was waterproof and has a Snapdragon 820 chipset. Here I use Sony Xperia X Performance Dual F8132 as a model to make videos.
Can I extract data from a broken motherboard?
Hi!
I have an Xperia X Performance with the motherboard broken in half. It’s (of course) broken in the slim bit, so that the charging port and LCD is broken off the main part of the board. I gave up as soon as I saw this, but figured I could check here if there’s anyone who have come up with a magical solution for this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Has the board been flexed in any way? Is the memory IC intact? If the connector is microUSB AB (Typical Android connector) you can solder a USB cable to the pins and attempt. If it’s USB-C… good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jens Frost 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 265
