跳转到主内容
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Keyboard and Trackpad no function
Dear all,
after an issue with coffee over the keyboard / sticky keys i decided to replace the keyboard instead of the whole upper case. All keys where working (but sticky) at this time.
Replacement of keyboard done - but then no reaction on the keyboard / trackpad. Also no backlighting available. The only functioning key is the power button.
After this i replaced the 2 flex cables for the keyboard and the trackpad, again no help.
Tried several resets with charging cable in or out / NVRAM Reset / battery plugged off and on and so on, all no help.
With external keyboard over BT and mouse via USB Cable i could use the MacBook, but its annoying.
After this I had no further ideas, so i brought it to a repair shop. They told me, the cheapest repair is maybe a new upper case, in a very bad case they have to change the logic board, but then the repair costs are the same as a new actual MacBook Air.
As the power button works with the new keyboard, I assume that there is a chance to restore the normal functions.
Any ideas of an additional reset or what i can do?
Anybody here, who had the same trouble in the past?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi Andreas Ulrich
you mentioned that there is a liquid spill.
Most probably some liquid has come in contact with the mainboard / logic board.
Be fast, as i believe corrosion is making the way to your mainboard now.
without schematics and tools it would be hard to check.
I suggest you to take to a professional service to check on your mainboard.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Andreas Ulrich 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 103
