跳转到主内容
在2017年6月,Apple更新了13寸的MacBookair,他换上了更新更好的Intel Core i5处理器,让性能和电池续航时间提高。
423 个问题 查看全部
What brands of SSD's are compatible with my Mac Air 2017?
My MacAir came with 128GB SSD, but that’s not enough, so I want to upgrade it. However, I don’t know which brand/specs to look for in a bigger one. Apple Store in my town gave me a big hefty price for any upgrades on that department, but I’ve found ssds cheaper on Amazon, however I don’t know about compatibility since I don’t understand much about this. Any help will be greatly appreciated. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Please keep us updated as to your success or failure as there are thousands of people in the same situation or will be in the future.
完成的
添加一条评论
1个答案
已选择的解决方案
So the SSD in here should be similar to that of early 2015, OWC drives are certainly compatible and are very easy to switch out, no extra work needed (follow the guide below). I personally have swapped mine for a Crucial 1TB M.2 NVMe drive, it works fine with an adapter (about $20) and I have had 0 issues and at about half the cost.
Some on iFixit, don’t like the adapter method for various reasons, but with High Sierra and onward the majority of the issues (hibernation issue for example) are no longer present. What ever option you chose the guide will walk you through doing the swap.
MacBook Air 13" Early 2017 SSD Upgrade to NVMe
这个答案有帮助吗?
得分 2
2条评论:
Thank you. I watched a couple videos and apparently I’ll need an adapter like this https://www.amazon.com/gp/product/B00QA7... and it should work with this ssd https://www.amazon.com/Samsung-500GB-SAT... (my model allows for 512 gb max, but that’s okay.
Thank you, again.
完成的
as @mayer said please post after install and keep us up to date, Please include, your OS, the Adapter you used and the SSD drive. As you see in the guide we are working to create a data base of the data.
完成的
添加一条评论
添加你的答案
Fabrizio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 1,195
