跳转到主内容
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
1049 个问题 查看全部
iPhone SE black screen
i have an iphone SE that is fallen while its charging and the screen goes black, i have tried to reset, change the display and change the battery but the problem still exists, itunes detects the iphone when is connected to the pc and i have already done the reset also with itunes, someone can have an idea of where the problem can be ? thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
These iPhone SE’s tend to have a lot of problems. It because it came out after the iPhone 6 and 6s. They put a bigger processor than the iPhone 6 inside of the SE. The next step I would do is try reconnecting the battery connector and the screen connectors. If that doesn’t work I would take it in to a local 3rd party repair store. PLEASE DONT TAKE IT TO APPLE! The 3rd party repair store should be able to do a diagnostic on the phone. Hope nothings wrong with the phone. Best of luck!!!
这个答案有帮助吗?
得分 1
2条评论:
thank you for the answer, i have tried to reconnect the connectors but the screen is still black, maybe there is a short on the logic board that i should not be able to find, i think i will contact a repair store, thank you again.
完成的
@Simone Any update on this?
完成的
添加一条评论
Reset the phone (no data loss): press both the home and power buttons for up to 1 minute, releasing when the Apple logo appears.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Simone 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 679
