跳转到主内容
加入维修社区 - 创建账户
24英寸显示器,内置iSight 摄像头,麦克风和扬声器。 1920*1200分辨率。 发布于2008年10月 型号为A1267
Random Black Screen - Backlight Off - Panel On!
Posting a solution to my own question as I have not seen this answer on here before!
24” Cinema Display - Random Black Screen - Solution
24” Cinema Display, connected to iMac 27” as an external display and it works fine however at random points the screen on the Cinema Display will go black. Checking the screen with a torch I can see the LCD is still on and working as it shows my desktop.
I have hot corners with display sleep turned on so if I move the mouse to the corner the Cinema Display (while already black) properly sleeps, moving the mouse a second later causes the screen to come back on again fully lit.
The time between black screens can be totally random. Sometimes it works for weeks with no problem. Sometimes the black screens return within minutes or even seconds.
Troubleshooting:
Reset PRAM / NVRAM
Reinstall OS - same problem on Sierra, High Sierra and Mojave
Open the Cinema Display and clear out any dust
Reseat all internal cables
None of these fixed the issue. Sometimes they would appear to resolve it but the problem always came back.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Solution:
I finally found a post online where someone was saying that they suspected that it could be caused by a bad LED(s) on the LED strips inside the LCD panel itself and that they had success by replacing individual LEDs on the strip.
I decided to take an easier route and looked up the model number of the LCD panel on Aliexpress and found sellers offering full replacement LED strips for $20. I purchased the strips - they come as a pair of 2 that sit along the bottom of the display.
Fitting is straightforward albeit somewhat daunting. The LCD panel assembly needs to be completely dismantled in several stages by removing screws around the bezel, slitting the sliver sealing tape and then easing the surround off by prying the display out of the plastic surround.
Once removed you can then get at the area the holds the LED strips, they are held in with screws and adhesive tape. Simply replace with the LED strips you purchased online and then carefully put the display back together taking care to avoid dust getting in between the various plastic sheets that sit below the LCD panel.
The whole exercise takes about 2 hours in total. It is NOT difficult provided you go SLOW - however it does look terrifying when you have the entire panel lying in pieces on your workbench. It requires bravery rather than technical ability.
For what it is worth I also have an iMac 27” that had exactly the same issue and the above process fixed that as well.
I have had no more black screens on either display.
这个答案有帮助吗?
得分 0
2条评论:
@horatio20 - Answers is really for someone with a problem needing help.
Your efforts here are appreciated !! But, you need to make a guide! Follow this Contribute! That way it doesn’t get lost in the sea of questions!
完成的
@horatio20 - You wouldn't happen to have a link or part number for these replacement LED strips, would you? I can't seem to find them on Aliexpress.
完成的
添加一条评论
添加你的答案
Horatio20 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 15
总计 528
