battery sign with a question mark in it
When i plug in my phone to charge im just getting a battery sign with a question mark in the middle of it? what does that mean?
Try a different cable, and charger transformer (plug into pc to charge. A question mark I've seen to be a few different things. Dust in phone charge port, battery took a crap. Or bad charger/transformer
这个答案有帮助吗?
OK thank you
Hold finger on Questiomark for while..
still not working..... im getting mad
1 ; either try cleaning battery
2 ; let your phone get cool
3 ; idk
If your lg k20 gives you a battery with a red question mark in it 😭😭😭 do a replacement with the battery my grandma's worker at work named Sam said it needs a new battery even with a 2 boxes one with the lg and one with a red question mark ❓ that
If u can't turn on the phone after a few seconds of holding down the power button, and the ? Battery when appears don’t disappear when plugging it in. Its probably either the charger or ur phone got overheated where it needs time to cool down for a bit. Once ur able to turn it on by the power cord then its fine. Just keep it out of intense heated places and keep it cool.
这个答案有帮助吗?
If you get anew battery note to remove the stick on the 4 battery connectors
im getting the red question mark. i just installed a new battery. please clarify "remove the stick" on the battery connectors. thanks
过去 24 小时: 7
过去 7 天: 33
过去 30 天: 165
总计 57,551
13条评论
My lg q6 alpha is showing the red question sign on the screen I don't what to do
由 careyellis18 完成的
What do I need too do if my phone want come on and only show a ? Mark
由 Samuel Houston 完成的
my lg is not turning on
由 Simon Weldemichael 完成的
I have a lg Stylo phone that I replaced the charging port in which was fairly easy. After getting the phone back together I plugged it in and all it will do is flash the battery sign with a question mark in the middle of it. How do I fix this?
由 mckinneymichael200 完成的
I have the same problem in my lg v10 question mark after connecting the charger
由 engineer malik 完成的
显示更多的8条评论
