跳转到主内容
screen upgrade for 17 inch mbp
So I own a 17” MacBook Pro 4,1 with a 2.5 GHz Core 2 Duo CPU.
I currently have the 1650x screen but I’ve heard they also had a 1920x1200 option. Can I upgrade to that display? If so what do I need to replace in terms of cables ? and got any particular model numbers?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
From EveryMac 17” MacBook Pro "Core 2 Duo" 2.5 GHz (2008:
17.0" color "antiglare widescreen TFT display" with a 1680 by 1050 native resolution. Apple reports that the default display also supports "1280 by 800, 1152 by 720, 1024 by 640, and 800 by 500 at 16:10 aspect ratio; 1280 by 1024 at 5:4 aspect ratio; 1280 by 1024 at 5:4 aspect ratio stretched; 1024 by 768, 800 by 600, and 640 by 480 at 4:3 aspect ratio; 1024 by 768, 800 by 600, and 640 by 480 at 4:3 aspect ratio stretched; 720 by 480 at 3:2 aspect ratio; 720 by 480 at 3:2 aspect ratio stretched".
*A higher-resolution 1920x1200 LED-backlit "antiglare" or "glossy" display is available by custom order. Apple reports that this display additionally supports "1680 by 1050, 1280 by 800, 1152 by 720, 1024 by 640, and 800 by 500 at 16:10 aspect ratio; 1280 by 1024 at 5:4 aspect ratio; 1280 by 1024 at 5:4 aspect ratio stretched; 1600 by 1200, 1024 by 768, 800 by 600, and 640 by 480 at 4:3 aspect ratio; 1600 by 1200, 1024 by 768, 800 by 600, and 640 by 480 at 4:3 aspect ratio stretched; 720 by 480 at 3:2 aspect ratio; 720 by 480 at 3:2 aspect ratio stretched".
Sadly this systems parts are very hard to find and the higher res display was not popular as it was quite an expensive option.
If you can get one of these MacBookPro8,3 - 17” MacBook Pro Early & Late 2011 I think you’ll be happier!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
raymond1212 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 120
