跳转到主内容
Repair guides and information for the HP 250 G3, a budget laptop released by HP in 2014.
25 个问题 查看全部
Laptop wont boot past "press f10 for bios" screen
Laptop wont go past the very initial screen which is just mentions the key yo go ijnto.bios setup. It gets to that screen, shutsoff and starts again and does this in an infinite loop.
If i go into bios setup, or diagnostics the screen does not shut off. Seems to only happen in the boot.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
keep pressing ESC key...
https://www.youtube.com/watch?v=GSN0qzXa...
are you able to go to system diagnostics?
check on the hard disk.
完成的
添加一条评论
1个答案
Enter the BIOS and find “Boot device priority” or “boot order”. Make sure the disk you have your operating system installed on, is on that list, and is selected as the first device to boot from. If that looks fine, then you can try to force a refresh. Turn it off and on, and, when you see the rotating loading symbol, hold the power button down until either the computer shuts off, or you see a screen that says something like "Preparing Automatic Repair" . If it just shuts off, try again. You may need to try a few times.
When you get to the automatic repair screen, select “Advanced options” and then “Troubleshoot”
Then select “Refresh your PC” and follow the instructions from there
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maira SALEEM 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 35
总计 1,374
