跳转到主内容
加入维修社区 - 创建账户
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Temperature to remove IC
Hi there!
What’s the best temperature in celsius degrees to remove the Wi-Fi IC and, after that, solder the new one?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
There isn’t a set recipe for doing micro-BGA work with a hot air station. Everyone develops their own style and methods based on the station they have and whether or not the temperature is actually calibrated or not. Generally speaking, I use 380C on my hot air station (Hakko FR810) and I adapt the time spent heating a component to the type of IC I am working on, the proximity to sensitive or critical IC’s, the possibility of underfill and component density surrounding the IC in question.
I would certainly start wth a lower temperature setting to pick at the underfill and then work on removing the IC at a higher temperature.
这个答案有帮助吗?
得分 4
2条评论:
Understood!
I'll try something around 380ºC because I think that my soldering station isn't calibrated yet (Yaxun 881d), but first I'll start with a lower temperature.
Thank you!
完成的
360C to 380C is the temperature most often seen in the repair community.
完成的
添加一条评论
添加你的答案
ryanlameiro 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,804
