跳转到主内容
Repair guides and support for the 3rd generation BMW M3, a high-performance sports coupe derived from the BMW 3-series (E46) platform.
4 个问题 查看全部
Cannot start my car
Hi Guys, when I try to start my e90 m3, i can't start the car. I am getting DSC failure and FTM error. I can hear the engine cranking and trying to start but it stopped after that.
I have called up several friends and they told me that battery could be weak. I have tried to jump start using another car battery but same error.
Any advice? Should I just try to change the battery?
Are the errors normal for a weak battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Ja Batterie gibt sobald sie zu schwach ist Alle Fehler an den Bordcomputer weiter die Fehler müssen gelöscht werden und die Batterie neu anlernen ( Die App Carly) mit dem Orginal Calry OBD 2 Stecker hilft dir alle Fehler zu finden und viel Geld zu sparen und immer zu wissen was dein Auto gerade braucht ;) Nice Day
完成的
添加一条评论
1个答案
From what I have found a low battery can cause things like DSC. Have the battery tested, most auto parts stores (at least in the usa) do this for free.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
roroeow7 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 288
