跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 123 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
2690 个问题 查看全部
iPhone wont charge with original cable and its discharging very fast
So I bought iPhone which came with original battery that said it had 80% health but I could use it maximum 30 min and replaced it with replacement battery but life on this battery isnt very good either. If I leave disconnected from charger at night in the morning its dead so even when its not doing anything its discharging. When the battery drops below 25% its start to lag and its unusable actually and sometimes this percentage at when its starts to lag varys, also now it lags when it has 60%. Does anybody know what could it be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Sounds like charging chip if it wont charge with original cable (make sure that cable works on another iPhone) but the lagging sounds like bad quality batteries.
这个答案有帮助吗?
得分 3
3条评论:
Do You maybe know the name of that chip?
完成的
It would be called U2 Tristar charging IC
完成的
Thank You very much! I found that some people replace U4, do You maybe know what he is?
完成的
添加一条评论
Tristar failure is a really good candidate for this problem, or you may have some corrosion on the logic board that is causing a partial short resulting in a low level current leak. Either way—these are microsoldering problems and it is time for a trip to your friendly local microsoldering/board repair shop.
这个答案有帮助吗?
得分 2
1条评论:
Well I was thinking of replacing it myself because I do know to solder with hot air gun so maybe I will give it a try on broken phone first then on my, thank You!
完成的
添加一条评论
添加你的答案
Electro Discover 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 98
