跳转到主内容
Laptop does not turn on but some LEDs light
Hello.
My low-end ZedAir laptop (it has non-removable battery) does not turn on and been trying to turn it on by the power button for hours.
I can’t figure out the real cause or factor that caused it unusable.
Maybe it is caused by the broken power button, or maybe the battery or maybe even the OS because I was able to open it before with the same issue, and LEDs are lighting up for 1 second after it was plugged in. Please help me!
Any help will be appreciated. Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Without proper diagnostics and tear down it is impossible to say 100% what is at fault, however one strong candidate is the battery has malfunctioned, this can also happen when they go totally flat without recharging for long periods. When batteries malfunction they tend to disrupt the power up sequence. Unfortunately your battery is non removable. If you are handy you could open it up and unplug the batteries from the board and try it again.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
PocketKent - Minecraft 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 47
总计 2,432
