跳转到主内容
This LTE capable Android Wear 2.0 watch could be purchased direct from Google or AT&T. It actually supports Verizon even though it isn't listed in the specifications. Model numbers are W280A or W281A
3 个问题 查看全部
lg watch replacement band
is their any way to replace the bands on a lg watch sport even thought the watches bands are packed full of NFC antennas and many more things needed for it to function properly one is broke and im not sure where to get a replacement piece
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
4条评论
model is w280A
完成的
Hi, I think the only way to get it is from here:
https://globaldirectparts.com/oem-lg-wat...
You have to buy both straps separately.
And yes, it's easy to replace them: Just remove the two screws on the sides of the strapholder and gently pull out the straps, by pressing them also slightly towards the backside of the watch. Like this you're able to click out the two bands, which have connectors towards the watch itself.
The new straps can be attached in the same way again... Good luck! (Have to replace mine too, as they have been proken both together now after only 2 years of usage! Crappy design... The next watch is for sure not a LG watch anymore...
完成的
There is a website that sells the bands for $35 per side but they are on back order.
I found a guy on ebay that sells refurbished ones that he makes with a 3d printer for $70 for both sides shipped.
https://www.ebay.com/itm/LG-Watch-Sports...
完成的
Then I found another guy that sells replacement bands on ebay without the antennas, so you have to remove the antennas from your origianl band and slide them into the replacement for $21 for both sides shipped.
https://www.ebay.com/itm/Lg-sport-watch-...
完成的
添加一条评论
5个答案
已选择的解决方案
YES! It’s easy… check out my new guide!!
LG Watch Sport Band Replacement
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Found it! they sell each separately https://globaldirectparts.com/oem-lg-wat...
这个答案有帮助吗?
得分 2
添加一条评论
这个答案有帮助吗?
得分 1
2条评论:
Wow, thanks for all those links! In my watch, the both antennas were broken also, but solution 1 and especially 2 sound good! And to be honest: I changed to the TicWatch pro 4G in the meantime and are really happy with it, especially regarding battery time thanks to the layered double display.
Well, on solution 2 just the protectors are printed with a 3D printer, the band itself is an original one as it looks like. Thanks for sharing!
完成的
You're welcome. Happy to share, hopefully it could help others in the future.
完成的
添加一条评论
I found my replacement straps on eBay, they really do have almost everything for sale on there.
这个答案有帮助吗?
得分 0
添加一条评论
for you that need a straps repleacment for LG W280 , i can provide it as a custom made by hand with leather based . just add my telegram @itbloon and i will send the pic .thankyou
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hayden Rogers 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 13
总计 5,066
