跳转到主内容
Repair guides and support for a wide range of radios.
246 个问题 查看全部
Why can’t I rewind my cassette tapes?
When I try to rewind my cassette tapes only the little metal rod in the bottom right corner spins, and my left cassette dock prong does not spin when I try to rewind. How can I fix this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Hi @spencer11234 ,
What is the make and model of the cassette player (or device in which it is located)?
完成的
It is a toshiba rt80/s and there is no problem with the actual cassettes. There are two prongs the cassette go on to play in my boom box and when I try to rewind none of them spin.
完成的
@jayeff *see above*
完成的
添加一条评论
3个答案
最有帮助的答案
Hi @spencer11234
It may be a loose (worn) drive belt or a dirty pinch roller or capstan.
You may have to dis-assemble the radio to gain access the cassette deck to inspect the belt and clean the pinch roller and capstan.
If it is the belt, unfortunately I have been unable to locate a supplier of the part.
I found this supplier but it appears as though the belts are listed by cassette deck model and not the model number of the device they’re installed in.
Hopefully the cassette deck model number is printed somewhere on your cassette deck and you can locate a drive belt using the deck number
这个答案有帮助吗?
得分 1
添加一条评论
Seems that the tapes are not been used for long time; this happens in unused cassettes as the tapes gets stick to one another. Hold the cassette in one hand and gentle tap it on your secondhand’s palm. Most of the time it should solve the issue. (This method needs to be done very carefully as there is a risk of tape getting damaged) In extreme cases you need to open the cassette and release the parts which are stuck together.
这个答案有帮助吗?
得分 0
添加一条评论
Hi @spencer11234
Did you solve the issue. My friend had the same problem and he sent his cassette tape to the repair center. They changed the belt. Usually they buy belts from Ebay or from this manufacturer from the first hands.
The price for the repair was 20 pounds.
Right now all works fine!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Spencer Jones 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 66
总计 3,841
