跳转到主内容
Repair guides and troubleshooting for the EasyNote TJ65-CU-030GE, a 15.6" budget laptop by Packard Bell.
No powering on, not even a light
EasyNote Te
Have tested the power cable (friends) so not the cable’power.
Have taken the battery out, held switch down for 20 sec’s then plugged in the cable, still no joy, not even a light.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
it may be a software or internal computor issue try go getting it repaired by a person licened to do so to avoid damaging your pc any further
完成的
添加一条评论
3个答案
This is internal damage, The Display Cable might be loose or damaged, you will probabally need a professional to remove the screen. Its easy to put the cable in but it is also very easy to destroy the cable.
这个答案有帮助吗?
得分 0
添加一条评论
Yes i did so,but still is not powering or showing any light
这个答案有帮助吗?
得分 0
添加一条评论
I've checked that and it's still not on
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alan Barber 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 23
总计 2,307
