跳转到主内容
Repair information and troubleshooting for the Harman Kardon Aura Studio 2, a bluetooth speaker with a microphone made by Harman Kardon and smaller than the Aura.
19 个问题 查看全部
not powering up when touching the panel
when connect to the power internal led blink once then touch the panel to power up the unit nothing happen. I have checked the power adapter by using multi-meter and it’s reading was 18.3v( adapter back side marked as 19v)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
4个答案
最有帮助的答案
It’s an easy fix. You have to disassemble speaker from bottom, remove screws, etc. Remove sensor ribbon and replace with a new one. I hope this helps you.
这个答案有帮助吗?
得分 2
5条评论:
Hola Marcelino González no sé si me puedes ayudar tengo 1 Harman kardon aura no prende y al abrir me fijé que tiene roto el plástico que lleva dentro pegado al entendido este es mi correo electrónico paparealmadrid@ail.com si me puedes ayudar gracias
完成的
Thanks for the suggestion, could you share the part number for the sensor ribbon or where it can be purchased please? I can manage to find it :-(
Thanks again
完成的
Were you ever able to fix this? I’m having the same issue
完成的
Marcelo noc si tú sabes o tienes alguna idea donde puedo encontrar o comprar el sensor para cambiarle la parte porque en el mío esta dañado el circuito para el apago del botón de encendido
完成的
Hola, alguien pudo comprar o cambiar el famoso sensor ribbon que comentó Marcelino? ... Saludos.
完成的
添加一条评论
can not turn off speaker, as soon as I connect it turns on and Does not let me turn it off
这个答案有帮助吗?
得分 0
1条评论:
Sameeeeeee when I connect my the HK aura studio it doesn’t let me turn it back off or connect to it with any device, does anyone know how to fix that or where can I take it to fix it????
完成的
添加一条评论
Where do you find the strip panel?
这个答案有帮助吗?
得分 0
添加一条评论
I could find the sensor ribbon in this website.
Assy touch board Harman Kardon AURA et AURA PLUS (mysav.eu)
Does anyone knows if this is the right one for Aura 2 ?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Maleen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 45
总计 4,903
