跳转到主内容
Repair guides and support for the eighth generation of Ford F-Series trucks: the F-150, F-250, F-350, and F-Super Duty.
58 个问题 查看全部
My 1987 ford f150 needs help
hi my 1987 ford f150 is not currently running because i haft to hold down the key to keep the the starter running to keep the moter running ive tried replacing the coil,alternator, soloniod, ignition switch and actuator , and also the battery if anyone can give me an answer plz let me know
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
You have two sources of power to the coil. One is when the engine is cranking and the other is when the key is in the run position.
You have no electric power in the run position to the coil.
Possible reasons are fuse to ignition burnt, broken wire to the coil or shorted wire causing ignition fuse to burn.
You will have to find and fix this wire or replace the fuse.
Michael
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
genral grizzly 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 487
