跳转到主内容
三菱汽车以及SUV的修理和支持指南。
114 个问题 查看全部
Mitsubishi Endeavor Driver side window controls won’t work
Hey i have a Mitsubishi Endeavor 2006. The driver side window switch won’t open or close any of the car windows. The switches on every other door can still open their respective windows. I bought a new switch and installed It but that didn’t fix the problem. I’m thinking It could potentially be the wire connected to the switch. I wanted to see if anyone thinks this could be the issue or if it’s something else. Also how to go about fixing It. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
The ground wire going from the door to the main body is loose or broken.
To much to go through to replace specific wire, you could run any new wire from door to body & see if its good.
Hold down the lock button on the driver & passenger door at same time, roll down driver window. All 3 buttons at once.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mlise785 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 252
