跳转到主内容
Repair guides and support information for Lenovo's 300 series of laptops.
147 个问题 查看全部
Why does my laptop only work when plugged in?
Hi,
i have a Lenovo ideapad 320S laptop which only works when the power adaptor is plugged in. When I remove the plug, the laptop will remain on for about another 5 minutes before shutting down quickly (despite the fact it shows 100% battery). I recently took it to currys pc world in which they claimed to have fixed it yet when I took it home the problem arose again (I’m guessing they plugged the power adapter in straight away to investigate the issue rather than seeing how the laptop worked on battery alone)
wondering if if there’s anything I can do myself or whether the laptop just needs a new battery ?
many thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
this is a good question/ but what is the answer?
完成的
添加一条评论
2个答案
最有帮助的答案
Most of the time, when a full charge only lasts a couple of minutes, it means that the battery is dead and needs to be replaced. With the information given, it sounds like this is the case.
To prevent batteries from dying faster in the future, try not to keep the laptop plugged in after the computer has been charged to 100%.
If your laptop is no longer holding a charge for long periods of time or always needs to be plugged into a power source to work, use this Lenovo IdeaPad U530 Touch Does Not Hold Charge problem page for possible causes and solutions.
这个答案有帮助吗?
得分 1
添加一条评论
Yeah you need a new battery I just looked it up and you need a new battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Leyla 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 1,804
