跳转到主内容
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
56 个问题 查看全部
Battery life after repasting
I have a 15” FHD dell xps 15 9560.
I upgraded the ssd to samsung 970 512gb
8gb ram to 16gb
& Repasted the pros & vga.
After doing so my battery life seems to be down to about 2/3 or 1/2 of what i had.
Battery condition is 100%
Do you think i did pasting wrong?
Any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If you mean you cleaned the thermal grease off of the processor and gpu then if it was not done right it would lead to overheat conditions. You should run the Dell diagnostics, restart computer and press F12 to bring up the menu and select diagnostics. The SSD you installed may be the cause of the power change, diagnostics should help with that.
这个答案有帮助吗?
得分 2
1条评论:
Corrected key to press for Diagnostics.
完成的
添加一条评论
添加你的答案
Malith Gayan Hettiarachchi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 222
