跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
MacBook Pro won't power on. Turned off at boot screen
OK, so basically I had just reset the MacBook pro
I was using a dodgy charger with some rips but overall it worked fine at an angle, it was on the final boot after I reset it and it suddenly shut off.
I think I clicked the tracpad 3 times and then it shut off? Could be related or not I don’t know.
But, basically now you can feel the force touch tracpad working but it stays completely dead. It charges and everything with a green light but it doesn't get hot at all and in fact its always colder than the room.
The only sign of life it gives is the working tracpad and the charging light on the charger. Need help I've tried all of the keyboard tricks like resetting the SMC Doing things while unplugging the charger and it everything.
It's been like this for over a week now please help
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Do a hard reset by holding the power button until something happens. Or you can try reconnecting the battery as well.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jakob Kenley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 4
总计 58
