跳转到主内容
A portable and water resistant outdoor speaker designed by Bose for uniform coverage from any angle. Bluetooth, voice commands and auxiliary connections allow multiple connections options for up to 12 hours of use. A lightweight version of the Bose Soundlink Revolve+.
19 个问题 查看全部
All LEDs on, No response
I have a Bose Soundlink Revolve+ and I recently got it really dirty and washed it off while playing music. Nothing was wrong and I continued use for over an hour even after drying it completely off, including the charging and aux ports cleared right after wash with CO². After playing music another 1.25hrs, I shut off the speaker and plugged it in to charge. The battery light flashed amber as it is supposed to, but after 30 min of charging it suddenly made the “power disconnect” tone and was stuck unresponsive with power, BT, and aux Led indicators on. What's the problem and how can I try to fix this? This unit is ~1.5 years old and past warranty by now…..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
did you find a fix for this? im having the same issue.
完成的
添加一条评论
1个答案
I think you might accidentally change the input to AUX mode.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Keene Y Leung 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 12
总计 460
