跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Top of touch screen won't respond to touch after screen replacement
I recently replaced the whole display of my iPhone 6S plus with the ifixit kit. I tested the touch functionality before sealing it up and everything seemed to be working fine. But as it turns out, the top 10% of my screen won’t respond to touch. So I can’t swipe down to get to notifications or use the Back Menu buttons in my applications.
I’m pretty sure I’ve got all of the connectors for the digitizer seated properly but I could be wrong. The rest of the screen works well and it’s just that top 10% that doesn’t respond.
Before opening it up again to check the connections, I wanted to see if there were any specific reasons why only the top of the screen wouldn’t be functioning. Hopefully that clue will give us a better idea where to start.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Usually it's either a faulty screen or connectors on the board and screen need to be cleaned. You can use isopropyl alcohol and a brush to clean both connectors. Sometimes dust in the connector stops the screen from having a good connection.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Allan Lam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 87
