跳转到主内容
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
1041 个问题 查看全部
What Repair Parts Are Needed?
I believe I have an iPhone 6s/plus (please advise how I can tell). The audio jack in the bottom of the machine is worn out from use and need replacement. In a separate issue, the microphone in the bottom of the unit stopped working when the phone got wet, although the speaker function in the same location continues to work.
I would like to repair both the speaker and audio jack. However, I dropped the phone and cracked the display up near the top. Would changing the audio jack and microphone disturb the broken glass? If so, I would like to replace the glass.
Please let me know what parts I need to make these repairs.
Thank you
Lou Danzico
[Email Redacted]
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
First how to know what kind of phone you have check the the model number on the back of your phone and usehttps://www.ifixit.com/Info/ID-your-iPho... to know what phone it is. For the headphone jack use thisiPhone 6s Plus Lightning Connector and Headphone Jack if its the iPhone 6S Plus. It will be hard to open the iPhone if the screen is cracked if you want to replace it use thisiPhone 6s Plus Screen only if it’s the iPhone 6S Plus.
iPhone 6s Plus Lightning Connector and Headphone Jack图片
产品
$24.99
iPhone 6s Plus Screen图片
产品
$64.99
这个答案有帮助吗?
得分 2
添加一条评论
Hi Lou,
The audio jack and microphones are all part of the lightning connector assembly. Parts and tools can be found here: iPhone 6s Plus Lightning Connector and Headphone Jack
This can job can be tedious, be sure to take your time.
As far as the glass is concerned.. Hypothetically you might be able to get a way with reusing the broken screen. I strongly advise against it. Usually cracks become worse during screen assembly removal.
Good Luck,
CW
产品
$24.99
这个答案有帮助吗?
得分 0
添加一条评论
Hi!!
If you are stuck on headphone mode (when you increase the volume it show headphone instead of volume)you would not be able to use your microphone also first thing you can do is a quick fix if it works for you. You first turn off your iphone and with a gentle hand you can pull out any dirt or particals inside your headphone jack with a pin then clean it with a cotton bud with a little acitone or alcohol ( Don’t use too much of alcohol only little would be fine orwise it could damage you display if it gets into your phone). Then after completing this process let it dry for a while and turn on your phone. I hope it works for you:) orthewise you have to replace your whole cc flex pannel.
If you have to replace it then you first paste a transparent tape on the broken glass so that it would be strengthen enough and won’t crack any more if you remove display carefully:)
Here you can get information about tools needed and process also iPhone 6s Plus Lightning Connector and Headphone Jack
Best of luck
产品
$24.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
loudanzico 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 77
