跳转到主内容
2015款 Nintendo 3DS XL,也被称为新 Nintendo 3DS XL,于2014年10月11日在日本发布,2015年2月13日在北美发布。
How to put the wifi chip on the board?
Hi, can anyone help me how to put the chip back on the board? Should i just solder it or also put termal paste?(can you draw with paint on the picture where to solder/put the termal paste) Or if any better idea can help me with this. Thanks in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
You will want to wick off the original solder and replace it with leaded solder. Apply flux and align the chip the best you can before using hot air on low air speed to solder the chip in place. You may need to go back and touch-up the pins with a soldering iron. You can check if you need to by using a fine tweezer and gently nudging each pin to see if it is soldered in place or not.
这个答案有帮助吗?
得分 0
3条评论:
okay thanks, i’ll try your method
完成的
hello sir, can help me about the hot air. any specific temperature?
完成的
Your hot air station is going to be different than mine. Leaded solder will melt at 188C/370F. So you can set your hot air at 10-20 degree increments above melting point until you find a good working temperature. It helps if your station has a calibration setting. Practice on a junk board before working on the 3DS.
完成的
添加一条评论
添加你的答案
Khairul Asyraf 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 213
