跳转到主内容
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 个问题 查看全部
How do you fix ghost touching without buying new screen
I dropped my iPad. I know what ghost touching is and I know how to fix it. But to fix it you need a new screen which is about 180$. I was wondering if there is another way to fix ghost touching without buying anything or taking the iPad apart.
Thank You
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
There's no way around this other than opening up the iPad and replacing the screen.
这个答案有帮助吗?
得分 2
添加一条评论
While the solution will likely involve replacing the screen, there is a small chance that the frame is bent and is putting pressure on the screen causing the issue. If you get really lucky, if the frame is bent, you might be able to fix the problem by bending the frame back to where it’s suppose to be.
这个答案有帮助吗?
得分 2
3条评论:
Thank you, I hope that is the case. But how do you bend it. I’m scared I’ll make it worse
完成的
My iPad was already cracked but it started happening when I dropped it. So I don’t think it’s the screens fault because it just started doing it. Do you bend it with a tool? Please reply in detail instructions please
Thank you
完成的
Sorry for the delayed response. They make tools to bend the frames back but you can use the edge of a table as well. Just be careful about how much you bend the frame.
完成的
添加一条评论
添加你的答案
AzN Moony 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 5
总计 127
